line weights
In view map or project map I can't get a pen 'line weight' distinction, yet it will print out with the correct line weight. It doing construction documents I need to be able to view these line weight distinctions while I'm working to make drawings pop. Is there a fix for this?
4 REPLIES 4
Stephen Dolbee
Go to "View/On-Screen View Options/True Line Weight"
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Thanks Stephen, wish the AC would make that the default setting....would have saved me a couple hours looking for answer.
Thanks.....
Different people, different tastes...
I, for example, like that True Line Weight is turned OFF by default.
So there is no solution that can please everyone.
Erich
While useful for checking how a drawing will appear, I find that having the True Line Weight setting turned on makes drafting less accurate. It is easy enough to switch on and off as needed.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
