Aussie John
open file in Archicad command in PM
I notice that using "open <filename> with archicad" in PM doesnt take you back to a section or detail view anylonger ( like it did in v8) Since it seems like such an obvious bug I assume it is a known bug. Anyone know?
Cheers John
[/size]
Although I'm on XP - I just had to try the condition you questioned. Several things have transpired in the process: I was able to open both plans, sections, details - both AC and ACAD, With the context menu and the file menu. However at the fourth item opened the program brought my system to a virtual halt - In the task manager the memory usage was 2-3% so the system was being affected some other way. I will contiinue to see if there is some other link that causes either of our problems. It ultimately crashed the system ---
Lew Bishop
P4 2.53 /1 Gig/ nVidia 420
AC9 1812USAFull
