PDF Printing from Plotmaker - Xtra Blank Sheets BUG ??
Hello,
When I use the Plotmaker / Print function using the PDF Amyuni driver,
to print a number of layouts all together at once, when I open them up later
using Acrobat Reader,there are at least 4 blank pages for every one with something on it.
The Bookmarks show only the pages with info, but the Thumbnails show a
whole lot more !!
Even when I print only one single Layout by itself, unless I specify
Pages From 1 to 1, I get the same result.
This really is a pain, as I have to "manually" do each Layout alone,
plus I can't combine them into one presentation.
Anybody else experiencing this ???
Naftali
ACv8.1 Plotmaker v3.1
i don't use the amyuni driver but i've had the same problem
solution:
in the print dialogue > plotmaker, change the setting to use 'margins of device'
and check that you're master layout isn't bigger than the printable area (in which case it will tile, which sounds like your problem)
bill
Djordje
Naftali wrote:
When I use the Plotmaker / Print function using the PDF Amyuni driver, to print a number of layouts all together at once, when I open them up later using Acrobat Reader,there are at least 4 blank pages for every one with something on it.
Everybody who does not:
- Set Amyni margins to zero
- Check the sheet fitting in the publishing set (Print Options)
So it is easy to sort out
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
