pdf creation problem
Hi
We just upgraded from ArchiCAD 10 to 11 and are beginning to use it. When creating plots or pdfs directly from Layout Views everything plots fine but when using the Organizer-Publisher, all the text and dimension text disappear from the final pdf. This was not a problem in 10. The computer is less than 1 year old (should not be an issue) and we're using Acrobat 8.0 Standard both with version 10 and 11. Any thoughts or suggestions?
0 Replies 0
