Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
pdf
Llian
i drag and drop a pdf [general notes, calculations, etc] into my layout sheet but the figure is showing it all black. did i miss something?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
5 REPLIES 5
Use the Drawing Tool to place the PDF. See if it works that way.
Llian
thanks....
Hi Laszlo, can ytou tell me the correct way to import Word docs into my layout sheets please. In a way that I can edit the text if needed
thank you
thank you
You can copy formatted text blocks in Word and Paste them in ArchiCAD, they will be converted into Text Block with the formatting. Then you can edit the Text Block.
But there will be no link between the two.
What you can also do is save the DOC file as PDF and place the PDF pages onto layouts. Those can be resaved in Word and updated in ArchiCAD as needed.
my placed pdfs (place as drawings) do not plot properly they have missing cut off areas
This was an issue with an older version 9 of 10
I am on a mac AC 13 and created these pdfs from word with the print option. The project originally Plotted OK
