plotmaker trouble - layout larger than printable page
problem..
while publishing multiple layouts in plotmaker, how to change the paper size of several layouts at a time?
another one.. i'm using pdf printer, so i'd like to define the location where the layouts will be print. Pressing publish, it prints all layouts, and gives a notice that all done and good.. but where were those pdf files saved.. couldn't find anywhere...
3 Replies 3
Erika Epstein
Kaur wrote:
problem..
1. In Publisher, "view set publishing properties" button
2. choose 'save files' from the drop-down menu in the upper right corner
3. click on 'Browse' and set the path to the folder of your choice.
I find it easier to set the path to a "Spool' folder on my desktop rather than change the destination whenever I print or plot. After printing or plotting I move the created files to their correct project folder.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Master layout.
Link
Yes - change the Navigator View to Tree By Masters and you can drag and drop a whole bunch in one go.
Link.
