2005-02-10
11:13 PM
2023-05-17
05:52 PM
Gordana Radonic
2005-02-17 10:49 AM
LewBishop wrote:Thanks, but I already use auto-rotate, and it works fine. The frustrating part is that the plotter pushes out blank paper for the missing area, i.e. a properly orientated full A1 plot, but with a blank strip (first edge out of the plotter). May try plotting upside down, to see if it helps!?!
By setting this direction I was able to get the title block end of the print to acually print. [...] for the 800 there is a setting that allows for auto rotate to fit, IMO.
2005-02-18 10:56 AM
richaney wrote:Are you guys sizing your Masters in PlotMaker to the paper specified?LewBishop wrote:Thanks, but I already use auto-rotate, and it works fine. The frustrating part is that the plotter pushes out blank paper for the missing area, i.e. a properly orientated full A1 plot, but with a blank strip (first edge out of the plotter). May try plotting upside down, to see if it helps!?!
2005-02-18 11:43 AM
"Djordje
[/quote wrote:
Yeah, masters are set well within the plot boundaries of the plotter. The layouts actually print out fine direct from PM, its just that we can't plot the full sheet of an archived PDF drawing - even though the PDF shows the full sheet on screen! PDFs also plot fine when sent reduced to our A3 laser printer - just not on the HP.
