2016-01-0901:47 PM - last edited on 2025-02-0711:58 AM by Aruzhan Hamar
printing
2016-01-0901:47 PM
I'm about to print some project in ArchiCAD for the first time, and I'm not sure how can I set line thickness (for walls, windows etc...). Can some tell me a way to do it? Thanks
Select the desired pen number for specific lines.
You can set the weight for the pen numbers.
To see the weight of the lines turn on 'True Line Weight'.
When you print it, it will print the different line weights.
When you don't want the line weights to be printed turn on 'hairline' in de print window.
Architectural construction designer, draftsman, modeller ArchiCAD 25.
