problems with layers and dimensioning styles
Hello,
I have the following problem in Archicad. The program keeps changing my dimensioning style from DIN tot METRIC every time i change between stories. Also it keeps changing the visibility of layers to some strange scheme. If I reopen/close visibility states manually and I change the dim. style to DIN, everything is OK until I navigate between the stories when it change them again. These changes only occur in Project Map but not in Layout Book. I wonder what happens.
Thanks.
Project Map or View Map? Views do save dimension styles, so if you are navigating by View Map it will change back to the saved setting.
I'm talking about the Project Map. In the View Map the dimensions are also wrong (metric) but in the Layout Book they are OK (DIN).
Later edit: It seems that the issue finally got solved by saving the file under another name.
