2004-02-04
03:34 PM
2025-02-10
04:47 PM
Aruzhan Ilaikova
2004-02-04 03:40 PM
2004-02-05 01:32 AM
2004-02-05 03:06 PM
Miquel wrote:Wow - no kidding! I'd have never found that! I wasn't aware that you could even change the type of link in the Drawing Usage window.
There is a way, but is not obvious. Publish your viewset from ArchiCAD to a folder as PMKs. In PlotMaker, link manually every drawing with the corresponding PMK using the 'Link To' button on the publisher (I have the spanish version so perhaps my translation is'nt fine). Once this is done, select all your drawings and change the type of link from 'Archive' to 'Project'.
That's all !
2004-02-05 09:32 PM
2004-02-06 09:51 AM
"Weston BlaneyWow - no kidding! I'd have never found that! I wasn't aware that you could even change the type of link in the Drawing Usage window.
Somewhat tedious process, but it worked like a charm. If one makes the mistake I did, this will recover the links - and keep all your drawings in exactly the same place!
I think this should go into the tips section.[/quote wrote:
It did.
2004-02-18 09:52 PM
