Helen123
blank views when importing from one teamwork file to another teamwork file
Hello! I need some insights on an issue we are facing here with a very large teamwork file. We thought of separating the file in 2 separate teamwork files, one with the model and the other with the layouts. When I import the views into the teamwork file with the layouts, the views are blank (only a couple of views loaded normally). We have tried relinking the view to the file, we have sent and received before importing the view but that didn't work either. We are using Archicad 26. Any help would be greatly appreciated! Thank you in advance!
0 Replies 0
