‎2016-06-21
11:10 PM
‎2023-05-19
03:53 PM
Gordana Radonic
‎2016-06-26 06:30 AM
‎2016-06-26 07:26 PM
David wrote:Thank you David, I see that this does work and I can adapt the solution to my needs. Even better would be the ability to produce a link like: <a href="https://xxx.com">Range</a>, or to be able to place a PDF in a (drawing/schedule on a) layout with an already formatted link as above.
Hi Paul
I did some experimentation with this and found the following.
If a link to a product web is placed in the Notes/Comment field of the object and the schedule which includes the object is saved as a PDF the link is maintained.
I added one to a door and have attached the PDF as an illustration.
The link should take you to a SMEG cooktop web page
Hope this helps
‎2016-06-27 12:40 AM
