save as dwg from plotmaker
Im new to archicad 8. Im trying to save as dwg in the layout book with no sucess. When I use the save as command from plotmaker it only allows me to save as lbk. format. I used to save as dwg from 7 but this is new to me. What Im doin wrong?
Link
Try Publisher>Publish...
Hit the 'View Set Publishing Properties...' button and select 'Save Files' as your publishing method. Define a path and hit OK. Then from your Project Map or selected Viewset, either drag over views or folder(s), or clone folder(s) that you want to publish to DWG. With these views/folders selected go down to 'Format' and select DWG. Use the 'Options...' button to set your Translator and whooshka - you're ready to save DWG's 'til the cows come home!
Link.
thank you very much. I wish the instruction booklets were as concise as your instructions
