Erika Epstein
setting margins using Amyuni driver for pdfs
I was recently asked why margins kept distorting(getting larger) when printing using the amyuni driver resulting in tiling. It is important to remember that when creating pdfs the plotter settings do not have any bearing on this. You must set the margins you want in the Amunyi driver settings.
Go to File, Print.
chose "Print setup"
"Properties"
"Advanced Options" tab
where it says "Physical Margins (set in Millimeters)" enter 0 for both horizontal and vertical.
The result is that it will use the margins of your master without adding increasing your margins.
Now I just have to learn how to spell Amyuni.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Jefferson
spelling is one thing, tell me how to pro-now-ounce it please!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Link
It's pronounced 'aim-you-knee'!
It's also important to note that in order to avoid tiling, your custom sheet size (set in the Amyuni PDF Converter), must firstly be big enough to accommodate entire Drawing, as set by PM's sheet size.
Amyuni works in metric (and doesn't allow decimals), so you may have to temporarily change your PlotMaker Drawing Units to mm to find out the metric sizes of your imperial sheets!
For example, a 24x26 sheet, is actually 914.4 x 609.6mm, so you will have to input 915 x 610mm as your custom sheet size, in the Amyuni Properties Dialog.
Then you''ll need to set your margins to zero as Erika pointed out. This will make it 100% sure that your PDF will have no unwanted scaling or tiling, as shown in the attachment.
Link.
