stretch wall at centre
Is it possible to stretch a wall in the middle to increase the dimension of the room?(refer fig)
i need to do so to avoid the work of realigning the windows.
thanks
5 REPLIES 5
rob2218
wont the "marquee" tool work? marquee the bottom portion of the windows, then simply stretch the wall(s) down??? or am I missing something here??
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Erika Epstein
Yes, the marquee is the way to do this. Check that you have the marquee set appropriately to light for active story only, or heavy for all stories. Also make sure grouping is suspended or you will just be dragging what you have selected.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
yes, got it.
but, how to to stretch trimmed to roof wall?the stretched portion sretches with original height.
thanks
Erika Epstein
You should do the roof separately unless you want the slope of the roof to change.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
A wall that is "Trimmed to roof" will not have the trim altered when stretching or changing the roof.
You will have to undo the trim and re-trim.
Solid Element Operations on the other hand will adjust automatically as you make changes.
