work with MarkUp
I often use MarkUp with team or other customers. Did is possibility to save the markup to pdf markup system and back?
7 REPLIES 7
The AC gives the possibility to import marks form DWF format files, but it doesn't work. I have Autodesk design review. Make the marks and save the file. when i tray to import marks in to the AC, didn't come any marks.
What i do wrong?
What are the exact steps you do when you try to import the MarkUps?
Also, do you save the redlining changes you do in Reviewer?
I import the Mark-Up by the Mark-Up tools.
in Mark-Up tool i choose add entries
then in New Mark-Up Entry choose the position "Import form Project Reviewer/DWF File"
and nothing ....
you can see on pic.
In reviewer file DWF format I make mark with markup tools. and save information on top in the same file.
I found that AC13 is not working with DWF file which was created by other soft, like Autodesk Design Review 2010. In this case i can't import the MarkUp from DWF created by Autodesk Design Review.
Is the way to import DWF markup form other softs?
Yes, ArchiCAD 13 can handle DWG/DXF versions up to AutoCAD 2009 only.
I suppose it can handle DWF 2009 too.
You could ask them to save the files in an earlier AutoCAD format.
I still trying to work with project reviewer, but have problems with dwf results. In dwf file all drawing is filled in black shade. I found that when you save to dwf format is possibility to choose the options to Replace huge fills, but it not give any affect on dwf drawing.
does somebody help me?
When you check that checkbox, do you also specify what type of fill to replace them with?
Because solid black fill is the default choice.
