visualization of dimension/furnish
I creaed my model with all the information about dimesions and furnishing. Now that I want to print I want to show on the same sheet both a building diagram with only the dimensions and an other one with only the furniture. How can I do that?
I tried to create two different work sheets, but then if I disable the furnishing layer on the first one, it is automatically disabled also in the second one.
2 ACCEPTED SOLUTIONS
mikas
Saved views are the key.
Make two layer sets, 1st with dimensions, 2nd with furniture. Save a view from each layer set then they are set as visible on your plan view.
First view "dimensions View"
Second View "furniture view"
Then make your layout dragging 1st and 2nd view to that same layout. Saved views will now keep their layer settings.
Same applies to other settings/atributes too, like pen sets etc. Views have to be used to save different settings from your model.
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
David Maudlin
neva:
The appearance of door and window markers is handled by Model View Options > Construction Element Options. Like the Layer Combinations mikas mentioned, you should create different named MVOs for each View, then assign the correct MVO to each View.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
mikas
Thank you very much, problem solved.
The only thing that I couldn't do is visualize doors and windows markers only in the dimensions view.
David Maudlin
neva:
David
