wall dimension - X,Y coordinates vs millimeter distance
hello
if you can help me with this - it would b greatly appreciated
when i began using archicad when i was drawing a wall in 2d the tracker would show the length of the wall in millimeters, n the angle...now for some reason the tracker is showing x,y coordinates
does anyone know how to switch back to millimeters????
thanks
1 REPLY 1
You may have changed the setting of the Delta (triangle) button on your co-ordinates palette.
