2017-11-08 06:09 PM - last edited on 2023-05-26 12:03 AM by Gordana Radonic
2017-11-09 01:44 AM
2017-11-09 04:40 AM
nancylee wrote:Did you check Floor Plan Display Options ?
drawing up a new plan in Archicad 20, which I'm still learning, and the walls are drafting in as gray and not cyan.
- walls on correct layer
- cyan is selected as the line color
- cut plane set to 3'-6"
the only way to make the walls show up cyan is to make the wall start 3'-1" below the floor level.
2017-11-09 05:29 PM
2017-11-09 05:43 PM
2017-11-10 01:40 AM
