Elevation Markers on Plan
Is there a way to choose the reference level for elevation markers on plan?
(like you can in the elevation and section windows)
I want to be able to choose(ON PLAN) whether to show 0'-0" (project level) or say 100'-0" (above sea level)
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
3 Replies 3
Is this what you mean?
It's under the settings for the Elevation (or Section) marker which you can directly access by right-clicking on it on the plan or on the project map.
David Maudlin
Thomas Allan Palmer:
If you are referring to the Level Dimension Tool, you can select just the text of a placed marker, open its settings, then select Custom Text and insert Autotext for Project Zero or Sea Level. You cannot select the reference level before placing; if you search the forum you will find other posts about this and maybe a poll.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David,
The auto text with reference to "reference level 1" set at the same height as the project altitude worked.
Bricklyne, Good screenshot of that. I was familiar with that function in the section and elevation windows.
Thomas Allan Palmer
