ā2022-06-07 05:29 PM
I've been using Archicad Sine V4.1 in 1992. I've upgraded off and on over the years. I recently switched from V22 to V25 and I'm not happy. Had already seen little improvement from 19 when I went to 22. here is my list of complaints after a month of using V25. some are carry overs from 22
Complaints of v25
BTW the stairs still donāt work worth a dam I still use the stairs from 19 or make my own.
I have finally been able to make one rail work but still canāt get it to do vertical pickets
I'm using mac pro16
ā2022-06-08 04:41 PM
so now i have to have cover fill on, did not have to do that in the past which goes to what i said about Archicad making things more complicated
ā2022-06-08 04:43 PM
thanks the drag and drop does work however thats s many steps as the old way so why the change. i don't use the recent list myself since for other reasons
ā2022-06-08 04:45 PM
I understand the reference but when I click on a beam it used to give me top and btm elevations in 22 now it only gives you the reference point so i still have to do the math in my head
ā2022-06-08 04:53 PM
I've tried to get the stairs to work over multiple hours over the last three years. i got one straight run to work once and saved as a favorite but it wouldn't let me do anything else with it. for me they are not intuitive at all. I watched a couple of videos and still no help. note it takes me minutes with the old stairs where it takes an hour minimum to get one straight stair to work. the new stairs won't let me set my own rise and run you have to pick form its list and even then one time it had the correct rise and run it wouldn't let me use it . go figure
ā2022-06-09 04:21 AM
No you don't.
If you know the height to the top of the beam, set the reference line to the top.
If you know the height to the underside of the beam, set the reference line to the bottom.
No thinking involved.
And you don't have to do the math in your head.
If you have a beam at say 2400 high and you want to lift it 600, highlight the height figure, type "600+" (without the quotes) and press enter.
It will do the math for you.
Anywhere you have a number, you can highlight it, type 000+ or 000- and then ENTER, and it will do the math for you (where 000 is the number you want to add or subtract).
ā2022-06-09 04:35 AM - edited ā2022-06-09 04:37 AM
You don't need to set the rise and run.
You set the bottom height ant the top height, tread length and number of risers you need.
Link the top and bottom to your storeys (you can use offsets if you wish).
Archicad will make the stair, and if you ever adjust the storey height, the stair will adjust automatically.
There are rules in the stair settings for min/max riser height and going length and min/max 2R+G, plus other rules.
These should be set to you local standards so you can not have an illegal stair, but you can turn these rules off.
Having the rules active will just give you the choice of available legal riser numbers or heights (changing one will set the other).
There is obviously a lot more involved but a simple straight stair should just be 2 clicks, once you have set the rules and linked the top and bottom.
If you need more help on specific topics, it will be best to start a new post for each one.
Rather than having 18 or so conversations on different topics all in this one post as we have going now.
I get magnetic selection even with cover fill turned off. Not sure why, but not complaining.
I've never had magnetic selection (which I always use via shift key) not work.
@Ron I can't think of why it doesn't work for you. Does it work with a cover fill?
ā2022-06-09 04:39 AM
Multi-plane roof seem to have an automatic surface - even with cover fills turned off.
Single plane roofs do not.
I tend to work more with single plane roofs, so forgot this.
ā2022-06-09 04:53 AM - edited ā2022-06-10 05:03 PM
@Ron wrote:16. When placing a fill origin I used to be able to set the origin before laying out the fill, best method, then it became after you place the fill, now you place the fill and it puts the origin at the center and you have to find it and move it to where you want it. Every change arhicad makes makes it more difficult not easier. NOW I HAVE TO DRAW A REFERENCE POINT TO WHERE I WANT TO MOVE THE ORIGIN TO SINCE I CAN NO LONGER SET THE ORIGIN FROM A KNOWN POINT
Apparently this was changed in version 23. The PDF Reference Guide for 25 (page 2070 English version) still describes the method for 22 and earlier.. with the cursor changing shape after drawing the fill outline to place the origin and direction vector. I'm told that Graphisoft will be updating the manual.
ā
ā2022-06-09 05:07 PM
for slabs and roofs it only works with cover fill on now
