yet another printing problem :(
Right then, so hopefully this will be the last problem I have for awhile... I'm starting to understand the "love hate relationship" consensus with plotmaker, so anyway, heres the wee problem i'm having with it now. when I draw the plans out and dimension / label them I go through and make sure the dimensions aren't on top of each other, and obvious problems like that, but I noticed that when I print them, the font seems to shrink a wee bit, and move about. heres and example: the first screenshot is from the drawing in Archicad, the second from Plotmaker. (Look at the door frame where it says "2'-6" dr.")
and the second...
hopefully some of you ahve ideas.
cheers,
Dan
disregard..... I've fixed this problem
cheers though
