zone tool that shows areas, heights and finishes
Where do I find this particular zone tool and load it into my project
4 Replies 4
David Maudlin
Archimamamia:
Go to Zone Categories... and select a Zone that has those parameters, there are a few Zones included in the standard ArchiCAD Library.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
How do I load the zone tool from AC16 into AC18 the one I want to use is Zone Identifier 1 16. Is there a way to load it into AC18, and if so, where is it stored in the Archicad file...
I want the Zone Identifier 2 16. Is it possible to load THIS into AC18...the one they have doesn't work for me.
David wrote:
Archimamamia:
David Maudlin
The Zones are stored in the ArchiCAD Library, like Objects and Doors. You can use the Extract Container... command to unpack the Object Library 16.lcf, in the unpacked library will be the Zones 16 folder which contains the Zones. This folder then be loaded into the AC 18 project with the Library Manager and the AC16 Zones will be available.
