zone
Hi! How do you centered the text of zone # in the zone?
Thanks
6 Replies 6
Dontknow
Do you mean centering the zone stamp or centering the text within the zone stamp?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Erika Epstein
Which zone stamp are you using?
Please add your AC version to your signature.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Sorry I am using Archicad 19
Dontknow
If you want to center the text inside the zone stamp you must first select the right stamp for your zone at Options-> Element Attributes-> Zone Categories.
You can't align the basic zone stamp.
Select the zone stamp 1
After setting the right zone stamp make your settings in 'Zone Selection Settings'.
You can set your alignment under 'Appearance'.
ArchiCAD 25.
Esdras Santos
Very nice tip! It helps me to solve a little problem with zones.
Thank you!
Esdras Santos | architect
www.esdrasantos.com.br
AC 16 64 bits BR - PC Core i7 2.60GHz 8GB - win10
Thanks, I just figured out
