GDL
Archicad 28- Where is the GDL reference Guide?
lopezfigueroa
This version no longer includes the GDL reference guide by default. The question is where we can get it updated. Does anyone know?
In the HELP menu > Online Resources.
https://help.graphisoft.com/AC/28/INT/GDL.pdf
You can download it as a PDF from there and add it to the Archicad documentation folder if you want.
Thanks Barry
