til0byte
Archicad 29: poly2_b{5} outline missing (covered by fill?) despite separate calls
Hi everyone,
I’m working on a 2D furniture object in Archicad 29 that changes its representation based on a custom Model View Option (MVO).
The Problem: The fills render correctly (Solid, Dashed, Colored), but the outlines (contours) are invisible in regular view. However, when I select the object in the floor plan, the dashed/solid outlines appear as part of the selection highlight. It seems like the fill is overlapping the outline, even though they are called separately.
I am using the poly2_b{5} command and I’ve already tried adding explicit pen resets before each call.
! ---- Standard Initialization ----
pen gs_cont_pen
fill gs_fill_type
! ---- Constants ----
DISPLAY_HIDDEN  = 1
DISPLAY_SOLID   = 2
DISPLAY_DASHED  = 3
DISPLAY_COLORED = 4
! ---- Read MVO Settings ----
_mode = 2
_ok = LIBRARYGLOBAL("ModelViewSettings", "iDisplayMode", _mode)
! Mode 1 = Hidden: draw nothing
IF _mode = DISPLAY_HIDDEN THEN GOTO 999
! ---- Determine Pen Color ----
_pen = 19
IF _mode = DISPLAY_COLORED THEN
    _pen = 85
    IF iResponsibility = 2 THEN _pen = 104
    IF iResponsibility = 3 THEN _pen = 114
ENDIF
! ---- Set Line Style ----
IF _mode = DISPLAY_DASHED THEN
    set line_type 25
ELSE
    set line_type 1
ENDIF
pen _pen
! ---- Main Body ----
IF _mode <> DISPLAY_DASHED THEN
    ! (1) Fill (Solid/Colored only)
    fill fillAttribute_1
    poly2_b{5} 5, 2, 0, 3, _pen, 0,
        0, 0, 1, 0, 0, 1, 0,
        0, 0, 1,
        A, 0, 1,
        A, B, 1,
        0, B, 1,
        0, 0, 1
ENDIF
! (2) Contour (all modes except Hidden)
pen _pen
poly2_b{5} 5, 1, 0, 3, 1, 0,
    0, 0, 1,
    A, 0, 1,
    A, B, 1,
    0, B, 1,
    0, 0, 1
! ---- Top Elements----
IF isVitrine = 1 THEN
    _vx = A / 8
    _vy = B / 12
        ! (1) Fill
            _vx,   _vy,   1,
            A-_vx, _vy,   1,
            A-_vx, B-_vy, 1,
            _vx,   B-_vy, 1,
            _vx,   _vy,   1
    ENDIF
    ! (2) Contour
    pen _pen
        _vx,   _vy,   1,
        A-_vx, _vy,   1,
        A-_vx, B-_vy, 1,
        _vx,   B-_vy, 1,
        _vx,   _vy,   1
ENDIF
999:
end
Has anyone encountered this behavior with poly2_b{5}? Is there a specific draw order or distortion_flag I might be missing to ensure the contour stays on top?
Thanks in advance!
2 Replies 2
Jochen Suehlo
Have you tried to let the object create the script. Here the outer lines are visible. Please compare it with your script. (AC 29 , MAC OS)
pen         24
fill "Misch-Schraffur 50 %"
poly2_b{5}       5,      2,      1,      3,     24,     91,
                   0,            0,     33,
                   0, -1.598563264691,     33,
        2.258005550405, -1.598563264691,     33,
        2.258005550405,            0,     33,
                   0,            0,     33
pen          1
set line_type "Volllinie"
                   0,            0,     33,
                   0,            0,     33
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
runxel
Any particular reason you are not using inline conditionals to flip the bits?
In my opinion keeping it DRY is a better style.
So I'd do it like this:
pen mypen
fill myfill
has_outline = not(_mode = display_hidden)
has_fill = (_mode = display_solid) | (_mode = display_colored)
poly_2b 4, has_outline+2*has_fill+4, pen_fg, pen_bg,
    0, 0, 1,
    ... etc.
Not sure what you'd need version {5} for in your code, but there it's the same.
