GDL
Are GDL arrays 0 indexed?
Jack D
I'm asking this since my supervisor is always starts array at 1.
DIM potato[]
   potato[1] = "russet"
   potato[2] = "yukon"
   potato[3] = "red lady"
To be honest, having 1 as the start of the index, kinda weirds me out but at the same time I'm also a bit curious if it is 0 indexed. Does this mean potato[0] does not exist or is potato[0] a none type?
DGSketcher
Legend
In GDL, arrays are always indexed from [1] or a 2D array would be [1][1]. Your example of potato[0] should throw up an invalid index warning when you check your script.
DGSketcher
Legend
ahh thanks! I've been looking for some mention if it's 0 index in the pdf guide but got nothing. Which got me thinking.
Here are the details of using arrays: https://gdl.Graphisoft.com/reference-guide/expressions#DIM_gdlcommand
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
