Automatically generate '2d Symbol' from shape of GDL object.
Is it possible to have a '2D Symbol' automatically generated from the shape of a GDL object that was created from written code (not created from the "Save Selection as..." command)?
11 Replies 11
Jochen Suehlo
The simpliest way is to use the following line:
PROJECT2 3, 270, 2
I hope, that this is what you meant.
The rest of the script can be commented (with ! at the beginning of each line)
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Thanks. That does do what I asked but I should have been more specific. The object I'm creating is a window. I need the '2d Symbol' to be cutting through the object like a section but in plan.
Lingwisyer
Guru
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=62584&start=10
PROJECT2{4} 3, -90,										!projection_code, angle,
	0, 1+2,												!useTransparency, statusParts,
	1,													!numCutplanes,
	gs_fw_lower + gs_int_fw + 2*gs_louvre_width,		!cutplaneHeight1, ..., cutplaneHeightn,
	3+32, 1+2+4+8+64,									!method1, parts1,
	gs_fill_type,										!cutFillIndex1,
	gs_fill_pen, gs_back_pen,							!cutFillFgPen1, cutFillBgPen1,
	0, 0, 0,											!cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1,
	gs_cut_pen,	1,										!cutLinePen1, cutLineType1,
	65,													!projectedFillIndex1,
	19, 19,												!projectedFillFgPen1, projectedFillBgPen1,
	0, 0, 0,											!projectedFillOrigoX1, projectedFillOrigoY1, projectedFillDirection1,
	gs_pen_2D, 1,										!projectedLinePen1, projectedLineType1
	4+64, 1+2,											!method1, parts1,
	gs_cut_pen,	4,										!cutLinePen1, cutLineType1,
	gs_pen_2D, 4										!projectedLinePen1, projectedLineType1
This post should probably be moved to the GDL thread.
Ling.
I pasted your code into the 2d script area but there is still nothing showing up in plan, are there any other steps I need to take?
How do I move this post to the GDL thread?
[Topic moved by moderator]
Not sure what changed but it is working now, thanks. It's not yet doing exactly what i need, but I will play with it for a bit and see what I get.
Lingwisyer, the code you posted only shows up as a single line in plan, see image below.
Lingwisyer
Guru
You will need to change those parameters to a cut height that works for you.
Also, since your object is a window, you will need to add a line to your code that rotates it when in plan view as the axis rotation is different between walls and doors / windows.
IF GLOB_VIEW_TYPE = 2 then				!Plan view
	ROTx 90
ENDIF
See the link in my previous post.
Ling.
That worked great. Thanks.
Is there anyway to only see the cut line and not the rest of the object beyond the cut line?
