GDL
Can i get the view name?
LeeJaeYoung
n = REQUEST ("Home_story", "", index, story_name)
story_name
I want get view name ?
I am trying to read the name of the floor plan in the view and use the IF statement.
<DrawingName>
2D Script
IF "<DrawingName>" = "3층 평면도" Then
TEXT2 0,0,"OK"
ENDIF
But This code doesn't work.
AC27 on window 11
2 REPLIES 2
Peter Baksa
autotext contents aren't visible to GDL.
In a drawing title object you can use these parameters to get some information.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
I want to read the name of the view.
Since this is a function that is only visible in the title, it cannot be used in an if statement.
AC27 on window 11
