2021-07-11
09:48 PM
2021-09-14
09:02 AM
Noemi Balogh
Solved! Go to Solution.
2021-07-13 08:20 PM
radius_of_circle = Arc Length/Subtended Angle in Radians r = s/θ
2021-07-12 01:21 AM
2021-07-12 10:51 AM
2021-07-12 11:33 AM
2021-07-12 11:53 AM
Barry wrote:No, I cannot. Wall accessory passing to the GDL object parameters values via Add-on (all information about wall geometry). There is no connection between label and Add-on. If I just set new parameter variable AC_wall_radius in label it will return me zero.
The 'Moldings and Panel' wall accessory works on curved walls.
Having a quick look at the scripts, it uses 'ac_wall_radius'.
So 'ac_wall_radius' will read the radius of the wall for you if you can use that in your label.
2021-07-12 10:08 PM
2021-07-13 02:00 AM
2021-07-13 03:10 AM
Braza wrote:
WALL_POSITION[1]
2021-07-13 08:39 AM
2021-07-13 11:31 AM
