2021-07-01
09:34 AM
2021-09-14
09:03 AM
Noemi Balogh
2021-07-01 09:57 AM
2021-07-01 12:17 PM
Joachim wrote:Thanks Joachim. I tried GDL-sublime and could convert to HSF. But when I try to convert it back to GSM, it is not happening. It does say it finished converting, but the file does not get changed. Have you used this tool? Can you help with this?
- GDLnucleus: https://gdlnucleus.com/
- GDLsublime: https://github.com/runxel/GDL-sublime
2021-07-01 12:54 PM
2021-07-01 02:25 PM
.\LP_XMLConverter.exe hsf2libpart E:\customObjects\test\hsf E:\customObjects\test\generated.gsm
2021-07-02 05:25 AM
2021-07-02 07:22 AM
2021-07-02 07:28 AM
dushyant wrote:
Hi Ling,
So how do you set up a local directory with GSMs in it as a live Archicad library?
2021-07-02 08:21 AM
2021-07-02 09:31 AM
dushyant wrote:
It does not auto-refresh the object after changing the GSM though. You need to reload the library, which takes more than a few seconds as it seems to reload all the connected libraries. So is this the bargain we have to make in order to use an external editor? Or is there a way around it?
dushyant wrote:Can you copy & paste the script from the external editor into the open object in Archicad?
It's definitely faster when you save the changes in the opened object in Archicad. You see instant changes in the placed object without any reload. If only the built-in script editor had syntax-highlighting & a dark background ...![]()
