minami
Creating an elliptical hemisphere
Is it possible to create an elliptical hemisphere like the image with GDL commands?
If so, what command should I use?
10 Replies 10
You could use a SPHERE and cut it in half.
Or better still there is an ELLIPS command that is half a sphere where you can control the height independent of the radius.
But in either case to elongate one axis, you will need to use the MUL command.
Lingwisyer
Guru
For the shape presented, ELLIPS would not work as that would create tangents along the cut rather than a Spherical Cap.
For the presented shape 3 variables would need to be defined. R1 you circles radius, R2 to distort it using MUL and H, used in conjunction with R1 to calculate R3, your spheres radius.
R3 = ( R1^2 + H^2 ) / 2H
With R3 in hand, you can then subtract H to set your CUTPLANE. OR better, offset your sphere into your cutplane.
Ling.
ps. Curious what would require such a shape... something that requires an object to be scripted...
DGSketcher
Legend
If you don't want to use GDL an alternative would be to use the Shell tool.
Basically you would draw a half ellipse and rotate it around the long axis by 180 degrees.
Or just use the 'ellipsoid' primitive shape object in the default library.
It even has a cutting plan for half an ellipsoid.
DGSketcher
Legend
🤔 I can't believe the primitives are localised but I'm not seeing that split option in the UKI library...
I only have 22 open at the moment.
This is what I see (AUS library).
Unless it has changed in later versions?
I just checked 26 and no there is no cutting plane option or hollow shell.
Why do they take options away?
There is a semi-sphere object, but you can not stretch it.
That ellipsoid I have in 22 may even be from an older library still.
It has no license restrictions or author information I can see, so I have attached it here.
Lingwisyer
Guru
Yep, Ellipsoid 22 does not have the option...
I checked out the origin of that object I posted and it looks like it is from version 10.
It seems newer amended objects are not always better (did someone say 'cabinets' ? )
