2021-01-11
05:10 AM
2021-09-14
01:31 PM
Noemi Balogh
2021-01-11 05:24 AM
2021-01-11 11:00 PM
I'm digesting this suggestion, but I'm not sure what you meant. An element can only have one renovation status. How do you reference ID / Category data / properties to the renovation filter?Although elements can only have one renovation status you can set up Renovation Filter schemes to determined how elements are viewed. Though this will probably have the same limitations you have discovered in Graphic Overrides.
2021-01-13 12:03 AM
2021-02-02 01:05 PM
Structural engineer, developer of free addon for sync GDL param and properties
2021-02-04 03:28 PM
kuvbur wrote:Awesome solution!
You can hide gdl-objects with MVO by IFC type
call "Filter_by_IFCProp" PARAMETERS ALL RETURNED_PARAMETERS show if not(show) then endBefore every master or 3D Script. Right?
2021-02-04 05:49 PM
2021-02-04 08:59 PM
LaszloNagy wrote:Still, every native element is derived from a similar structure deep down, implementing it to every native tool doensn't seem like rocket science from a coding point. (from what i understand based on the API structure).
vdentello,
Yes, the solution is great, but there is one problem: it works only for GDL-based element types.
The original poster, however, wants to hide any element type by classification (Walls, Slabs, etc.). So, I think if GRAPHISOFT implements a solution, it should be one that works for all element types, not only element types based on GDL.
2021-02-05 06:26 AM
