PeterPetersen
Defining values of ArchiCAD propoerties through a GDL script
Is it possible to set ArchiCAD property values through a GDL script? E.g. I am creating a library of objects, where I want to include information about the Manufacturer, Product Name and Article No.
All these are preset ArchiCAD properties.
So far I could only get these included in the Description tab of each object, but I cannot link these with properties.
1 Solution
An Archicad object (GDL) does not have properties - only parameters.
Only a placed instance of that object has properties base on its classification.
And a property can not read object parameters unfortunately so you can't create an expression to read an object's parameter.
Go to post
4 Replies 4
PeterPetersen
Thanks Barry, you saved me quite some time trying.
Xandros
As Barry mentioned, it's not possible to convert GDL parameters into properties.
But there's a possibility to convert those into ifcValues, which you can label / put them together in a schedule / export to ifc.
I'm a bit lazy to translate, but since your screenshot is in german, here's an old forum post in german explaining the steps:
https://community.graphisoft.com/t5/Modellierung/Etikett-f%C3%BCr-Stahlbauteile/m-p/561870/highlight...
And there's a video (also in german) by @Lukas Oelmueller that covers the topic:
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
kuvbur
You can read property with addon ttps://github.com/kuvbur/AddOn_SomeStuff
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
