ā2024-11-05
02:50 PM
ā2025-03-31
12:22 AM
I'm looking for a way to alter the opening lines of a double door separately. In the 'door selection setting' it's only possible to override both opening lines of the door. I'm slightly familiar with GDL code but I can't manage change the 'door selection setting' to two separate parameters, one for each doorpanel. Is there a way to achieve this?
Operating system used: Mac Intel-based
ā2024-11-05 02:58 PM
It will not be possible in the object settings unless there is already a second line type parameter for the second door.
But I am sure you would have seen it, if it was there.
I don't use these doors so I am not familiar with them, but I would be very surprised if it was there.
The only solution would be a GDL one, but it is not recommended to alter Graphisoft objects, because every time there is an update, you will have to re-do the change.
If you are wanting to investigate a GDL solution, I will move this post to the GDL forum.
ā2024-11-05 03:03 PM
Hi Barry, there is indeed no second parameter for the second door.
You may move the post to the GDL forum. Thanks!
