2020-06-01
09:00 PM
2022-09-26
10:54 PM
Daniel Kassai
2020-10-13 06:31 PM
These registry keys are experimental features. We don't want to keep compatibility with their values, they might change. They aren't stored in the plan, others might see the model differently.HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD\ARCHICAD <version>\GSModeler\Better GDL Tube TriangulationMaybe Peter can shed some light onto this one![]()
2020-10-14 11:39 AM
Peter wrote:I recall passing thru this on an object I scripted ages ago (With the precious help of many good friends here
Yes, the tricky part is the direction of the 0° direction on that plane. It is the projection of the Z axis to the plane, but sometimes is flipped 180° so the tube is less twisted. Sometimes this flipping is not needed for the model, but it can't be controlled intuitively.
Hmooslechner wrote:Yes. I think that a proper road/street tool will have to be much more complex than that.
There is another problem with streets: in curved sections, they usually are broader than in straigt directions - sections. Here the tube-command comes to its "boarders". The trailing-curve comes into the topic.
2020-11-18 06:03 PM
2020-11-19 08:07 PM
Hmooslechner wrote:
I want to point you at my last polyline-Object on the foundation of sinceV6:
Profile-manager - profiles are used to follow the 3D-Polyline-Curve
2021-09-02 10:10 AM
Hi! Thank you for the object.
I found that the object stop to work with two points on my projects: I can't add any more points to the polyline. Do you know where it come from?
2021-09-21 06:26 PM - edited 2021-09-21 06:26 PM
How many points did you use ?- if i remember right - its limited somehow 50 or 100 points or so- just add a new object to prolong it.
2021-09-22 09:36 AM
Just two points in total.
2021-10-09 07:09 AM
There is also a minimum of needet points to it.. but i didnt test this, because i always uset more points.. logoically 3 points?
2021-10-11 10:17 AM
It works with 3 points. The problem is that the object lets the user reduce to 2 points, and then, the object is blocked.
a month ago - last edited a month ago
sinceV6: You are the real genius - i am just a little kid standing on the sholders of "You giant"!
Several AI-Systems didn't get Your System into their mind. Gemeni got the farest on this, but made several suggestions to optimize it, but faild every time. So i told the AI's not to change a single character of Your polyline - not to "verschlimmbessern" it (german Word for making something better bat getting it much worse)
Just to mention - "car-edge-tracks" following Your Polyline-concept.. AI-supported:
Archicad29 Schleppkurven Sattelzug KI Polygon
AC29EduAut:
