Aussie John
Extend a Zone into Door opening
Somewhere between my version jump from v12 to v22 zones stopped extending into a door opening. Any suggestion to fix this or is a GDL object code line needed?
Cheers John
[/size]
19 Replies 19
Aussie John
Interesting Barry
I too have used custom doors (see screen shot) and they follow frame depth but not the reveal depth. The GS doorframe (red) reacts to the zone with frame depth AND the setback.
Something very odd and again I call a bug.
Cheers John
[/size]
Yves
These parameters are well adjusted ?
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
The parameters Yves is referring to can be accessed by opening the Door element for editing in the GDL Editor.
Then on the "Details" page click the "Compatibility Options" button, and you will find the "Nominal Frame Thickness" and "Parapet Wall Inset" parameters at the top.
I tested this a little bit and found that it is possible to modify the two fields, then save the Door, and update Zones, the Zone polygon will indeed extend into the Door and the Zone polygons on the two sides of the Door will join (be adjacent).
In the default "Door 24" Door element, the two fields look like this:
"Nominal Frame Thickness":
gs_fthk
"Parapet Wall Inset":
(pwi=0)*(-1) + (pwi=1)*0 + (pwi=2)*WIDO_SILL + (pwi=3)*(WALL_THICKNESS - gs_fthk - WIDO_SILL)
As you can see, the gs_fthk parameter, which stores the frame thickness value of the Door, appears in both formulas.
So we need to modify the two fields to remove this parameter, as follows:
0
(pwi=0)*(-1) + (pwi=1)*0 + (pwi=2)*WIDO_SILL + (pwi=3)*(WALL_THICKNESS - WIDO_SILL)
With these modifications, the Zone polygons join properly. The Door on the left is the Door I modified, the Door on the right is the default GS Door.
Just be careful with the nominal frame thickness.
It is a long time since I have played with it but I believe it affects the position of the door when you 'Flip' it.
Having it set to the frame thickness, the door frame will stay in position when you flip it, Set it to 0 and you may find the door frame flips about the reveal offset position (i.e. the front side of the frame).
Just tested it with a saved an modified copy of my door and this is what happens.
I have never dealt with the parapet wall offset so I am not sure what that will affect.
Yves
Effectively
WIDO_FRAME_THICKNESS frame thickness of window/door
when flipping doors/windows, they will be mirrored then relocated automatically by this value
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Does this happen with you custom Doors?
Because I checked AC24 and it does not happen either with the default Doors or the Doors with the modifications detailed above.
Yes that image was my custom door.
But I also just tried with the standards GS 'door 23'.
Saved it as a new object with the nominated frame thickness set as 'gs_frame_thk'.
Then saved as again with the nominated frame thickness set to zero.
The frame is in a different position and now jumps when the door is flipped.
Barry,
You have to change the definition of both the "Nominal Frame Thickness" and the "Parapet Wall Inset" parameters. If you set only the first, the above issue will occur.
I know because I did the same.
Strange I am still getting the same result.
The original parapet wall inset formula is ... (pwi=0)*(-1) + (pwi=1)*0 + (pwi=2)*WIDO_SILL + (pwi=3)*(WALL_THICKNESS - gs_frame_thk - WIDO_SILL)
Whether I change it to ...(pwi=0)*(-1) + (pwi=1)*0 + (pwi=2)*WIDO_SILL + (pwi=3)*(WALL_THICKNESS - 0 - WIDO_SILL)
or just ... 0
seems to make no difference for me.
I am not sure why this formula is there as that 'pwi' parameter has a value of '2' and is hidden from the user - so can't be changed diirectly by the user.
So unless it is set somewhere in the parameter or master scripts, the formula could just be written as 'WIDO_SILL' (as that is the only part of the statement that is true with the default pwi value).
I am sure it is set somewhere in the parameter or master scripts based on other values, but trying to track it down in a GS object is a bit of a challenge.
When I get some time I might try to look into it.
Peter Baksa
http://gdl.graphisoft.com/gdl-basics/simple-doors-and-windows says that flipping moves the object by the nominal frame thickness, but it can be modeled/drawn differently based on WIDO_REVEAL_SIDE.
http://gdl.graphisoft.com/tips-and-tricks/linking-openings-to-zone might help John's reveal problem.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
