LeeJaeYoung
How can I get the zone name from label gdl?
ROOM_NAME is Room parameters (available for Zone Stamps)
AC27 on window 11
1 Solution
!see ac25 built-in parameters
!2d script >>
n = REQUEST ( "Property_Value_Of_Parent", "Builtin.Zone_ZoneName", type, dim1, dim2, propertyValues) !see ac25 built-in parameters
!!define style....
text2 0,0,propertyValues
Device name Asus v16
Processor Intel(R) Core(TM) 5 210H 2.20 GHz
Installed RAM 16.0 GB
Go to post
5 Replies 5
!2d script >>
!!define style....
LeeJaeYoung
thank you
But when I do this, it doesn't link with the zone
n = 0, so no value appears.
It would be really appreciated if you could tell me the function for linking in the label.
AC27 on window 11
LeeJaeYoung
I found out while testing that the zone label 25 and zone could not be linked with the label tool.
Up to this point, I forgot to link with the label created when creating the zone.
thank you ^^
AC27 on window 11
LeeJaeYoung
: how can i see it?
propertyValues
: DIM propertyValues?, propertyValues[]??,propertyValues[]??
  Which one?
:  Is it possible?   I can't do it now.   What should I study?
AC27 on window 11
Peter Baksa
Property_Value_Of_Parent always returns a one-dimensional array. It also returns the array size dim1 and dim2. You have to interpret the array accordingly.
dim1 = 0, dim2 = 0: simple, scalar value at array[1]
As far as I know, property values can't be two-dimensional.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
