LeeJaeYoung
How do I match the gdl together?
Is it something other than transfer all setting?
Does the funny thing change every time you do it?
I think it's a bug...
AC27 on window 11
6 Replies 6
I've written you privately in the past about this... but I'm not seeing any improvement:  your command of English seems so minimal, that this post makes absolutely no sense.  Please use Google Translate to be able to write a detailed question in Korean and then have it translated to English for pasting here.  Thanks! 🙂
LeeJaeYoung
sorry. I only speak translate.google.com. Because the English I know may be wrong.
This is the result.
As you can see, both have the same settings.
But in 2D, it's a different shape.
And I got a different result before, but it was different from what it is now.
I'm just talking about the bugs I see while doing it.
AC27 on window 11
LeeJaeYoung
I changed the GDL settings above to have the same result. With 250, of course, the one on the left is 0.
And I don't do any other settings.
AC27 on window 11
LeeJaeYoung
1. this is left (reset and reSetting GDL)
2. Right
The interesting thing about this is that if you transfer all settings to No. 2 at No. 1, it will have the same shape.
However, the lower one is like this if you set the transfer all setting. Of course, the setting values are the same.
AC27 on window 11
LeeJaeYoung
It seems that my English level is still difficult to understand.
sorry. Is this the best expression I can say? ^^
Still, thank you for replying to my words that are difficult to understand. ^^
AC27 on window 11
LeeJaeYoung
The concrete section line is a thick line and I don't know how to deal with it.
AC27 on window 11
