Gabor Szelei
How to run a macro's parameter script from a main object without code duplication?
Hi Everyone,
I have created a modular sub-object (macro) that includes its own Parameter Script to handle dynamic value lists (values commands) and parameter constraints.
I want to call this macro from a Main (controller) object. Currently, it only works if I completely copy-paste the macro's Parameter Script into the Main object's Parameter Script. If I don't copy the code, the dynamic drop-down lists do not appear or work in the Main object's default parameter list.
My question is:
Is there a clean, simple way to trigger or execute a macro's Parameter Script from a Main object without duplicating/copying the code into the Main object?
I want to use the standard default parameter list of the Main object, and I would like to avoid building a custom Interface Script if possible.
Thank you!
Gábor
Operating system used: Windows 10
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
1 Reply 1
If you have the same parameters in the list of your main object that you use in the macro, you should then be able to call the macro from the parameter script in the main object.
You can hide the parameters in the main object if you don't want the user to see them.
