LeeJaeYoung
Is it possible to write GDL API in chatgpt or claude ai?
If possible, what is a well-trained ai?
AC27 on window 11
16 Replies 16
Ahmed_K
Mentor
That's the idea, AI needs to be filled with data, feed it with tons of exemples, and it generates new objects from what it learns,
I'm sure it can be done, and once it works, boom,
Archicad 27
Windows 11 professional
jl_lt
Ace
ok, just not in my computer 🤣     i still dont trust that thing
LeeJaeYoung
ChatGPT still does not fully understand GDL.
Isn't this because the Archicad GDL format is unreadable, like a .docx file?
And isn't it also because Graphisoft hasn't taken ChatGPT into consideration?
Why isn't the GDL source code made available for training purposes?
It has been a year, but there has been no meaningful progress.
It seems that the manual has been read, but it appears to be an outdated one, as the parameter names differ from those currently used.
Do you know that GDL is considered both the greatest strength and the greatest weakness of Archicad?
Many users hope that AI will allow easier access to GDL, and we sincerely ask that you support such development.
AC27 on window 11
Zofa
I tried to make an object in Claude Code. It can make a HSF directory with all xml-files. On my Mac I use the LP_XMLConverter.app to maken a gsm file. This works. The LP_XMLConverter.app is part of Archicad (show content).
Claude has te learn a lot but it can sure help.
Hmooslechner
I recently made some very complex gdls with the help of gemeni3 (Google AI) like this:
Its in german, just as example whats possible with this. You have to be very patient and sent all failure-answers from Archicad direct to the AI and then the magic happens. The file is in the Video-Text für Download. AC29EduAut.
marcoariveross
I don't know if it's real, but this is in development:
https://www.linkedin.com/posts/v-k-t-r-s_image-ai-archicad-activity-7430433772849987585-9XPT/?utm_so...
BIM Manager Pavimaq
Lima-Perú
Archicad 29-Windows 11-64Gb RAM
Hmooslechner
Maybe  - have a look at this german task in this forum. I made some Polygon-Fill GDLs with circles und a kind of Voroni-structure even in 3D with the help of DeepSeek AI and Gemini 3.1 AI:
https://community.graphisoft.com/t5/Programmierung/2D-GDL-Kreise-verteilen/m-p/693573#M8325
this is Esteban Ramos dynamic polygone-Code - filled with this structures.
If someone wants to try it: AC29EduAut: https://www.dropbox.com/scl/fi/hpw91huipdudxo3fiw7p0/Kreise-verteilen.pln?rlkey=jdrfq2l2sjqr3tnnvxxv...
