Is there a tool / object for making a mesh with a specified thickness?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-08-30
09:12 AM
- last edited on
2024-09-15
02:55 AM
by
As in the topic, I wanted to ask you guys if there exists any tool that would allow me to create a mesh with a specified thickness, or layers.
For example, I have a terrain to model, but the ground has layers: 3cm of grass, 10cm of ground, and some other layers. The terrain is not flat - it has some holes and bumps. Is it possible to create this with one tool/object, not using layered slabs, roofs, and shells?
- Labels:
Library (GDL)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-30 11:04 AM
Regards
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-08-30 12:27 PM
Does anyone know other solutions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-01 12:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-03 06:07 PM
gedzior84 wrote:Try this object I've recently created.
For example, I have a terrain to model, but the ground has layers: 3cm of grass, 10cm of ground and some other layers. The terrain is not flat - it has some holes and bumps. Is it possible to create this with one tool/object, not using layered slabs, roofs and shell?
It can add 6 skins from a Mesh saved as an object. If you need more tell me.
The skins are not really composites, as they are just offset of the original mesh object. But the result is pretty acceptable IMO.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-03 07:03 PM
It's amazing how many things can be made with your object!
Thank you very much - it's a lifesaver
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-03 07:24 PM
BTW: As a tip, regarding irregular mesh shapes, I suggest you to place a 2d hotspot on a mesh node and save it with the mesh too. This way you can precisely place the object on top of your original mesh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-04 07:38 AM
Thanks so much!
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-04 10:39 AM
Let me know if you find any glitch on the code.
If it gets stable I will put it on BIM Components.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-09-04 04:49 PM
To avoid one more SEO on the project file.
