‎2021-05-15
02:12 PM
‎2021-09-14
09:12 AM
Noemi Balogh
! "Steckdose_typ" is an array with values and descriptions
rrr = request ("ASSOCLP_PARVALUE", "Steckdose_typ", Steckdose_typ)
AC_MarkerText_5 = PARVALUE_DESCRIPTION ("Steckdose_typ") ! this didn't work
AC_MarkerText_5 = str ("%.0", Steckdose_typ) !I got the value as number
Question 2:text2 0.125,0,AC_MarkerText_5best regards,
‎2021-05-15 03:29 PM
ADD2 LABEL_POSITION[2][1]+LABEL_POSITION[3][1], LABEL_POSITION[3][2]
‎2021-05-15 04:06 PM
‎2021-05-15 04:41 PM
dim p_values_and_descriptions[]
n = REQUEST ("ASSOCLP_PARVALUE_WITH_DESCRIPTION", "Steckdose_typ", name_or_index, type, flags, dim1, dim2, p_values_and_descriptions)
for i = 1 to vardim1(p_values_and_descriptions)
text2 0, i, p_values_and_descriptions
next i
‎2021-05-16 09:41 AM
rrr = request ("ASSOCLP_PARVALUE", "Steckdose_typ", Steckdose_typ) rrr = REQUEST ("ASSOCLP_PARVALUE", "Steckdose_typ", name_or_index, type, flags, dim1, dim2, Steckdose_typ)
‎2021-05-16 12:03 PM
! Step 1: Requesting the values of parameters in objects
number_of_sockets = 1 ! Parameter 1 (Integer)
n = request ("ASSOCLP_PARVALUE", "Steckdose_anzahl",name_or_index, type, flags, dim1, dim2, number_of_sockets)
dim p_values_and_descriptions[] ! Parameter 2 (array)
! Step 2: Inserting the values in textfields
font_size =1.5
font_size_m =font_size/1000*GLOB_SCALE ! font size in meters
DEFINE STYLE "fontstyle_label" "Candela Book",font_size,4,0
SET STYLE "fontstyle_label"
ADD2 LABEL_POSITION[2][1]+LABEL_POSITION[3][1], LABEL_POSITION[3][2] ! to move the Text to the origin of the Label
offset_textbox = 0.075 ! offset between the text and the object
! Inserting the value of parameter 1 and only the description of parameter 2
for i = 2 to vardim1(p_values_and_descriptions) ! i=2 to skip the the value of parameter 2 in the array
text2 offset_textbox,0,str ("%.0", number_of_sockets) + "X " + p_values_and_descriptions
next i
! Inserting the elevation of the object as text
text2 offset_textbox,-(font_size_m+0.005),"H:" + STR(GLOB_ELEVATION,5,2)+ "m"
! a fill to make the selection of the Label easier
width_textbox = 0.5
add2 offset_textbox,font_size_m-0.02
fill "Nur Hintergrund-Stift"
poly2_b{5} 5,2,1,3,195,0,
0,0,1,0,0,1,0,
0,0,33,
0,-font_size_m*3,33,
width_textbox,-font_size_m*3,33,
width_textbox,0,33,
0,0,33
! drawing a line to the object
line2 0,0,-0.1,0
‎2021-05-16 01:40 PM
‎2021-05-19 09:29 AM
Ah, of course, PARVALUE_DESCRIPTION ("parameter") is not working, because it's the wrong command. It simply does not exist in GDL.It does exist, you need to specify array indices when using it with an array.
