Bruce
Zone data via attached label
Now we can attach labels in AC26, I thought I'd create a GDL label to match my company's zone stamp.  However, I can't find any way to extract all the necessary data from the attached zone.
There is the ZONE_RELATIONS request, but that doesn't return any area data.  I've also tried the ASSOCLP_PARVALUE request, but that doesn't work either.
In particular, I'm after the different types of areas; but I also need to retrieve parameter info.
Any ideas?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
1 Solution
Jochen Suehlo
This is documented in the GDL-Manual under the following header:
BUILT-IN PROPERTY GUIDE
Example Script for room number:
_actProperty = "Builtin.Zone_ZoneNumber"		! Room Numebr
m = request ("Property_Value_Of_Parent", _actProperty, _typeValue, dim1, dim2, _propertyValues)
_inhalt_2D[i] = _propertyValues
Note that not all zone parameters are available for labels.
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
Go to post
4 Replies 4
kuvbur
Also faced the same problem. Looks like ASSOCLP_PARVALUE doesn't work with zone members. It is strange that such a restriction is not described in the documentation.
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Bruce
This is a brand new feature, so I imagine they will work through such things shortly...
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Jochen Suehlo
Bruce
Thanks Joachim - that's what I was looking for!
This solves 85% of what I need.  What is missing is the parameter requests for the zone.
Thanks again.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
