jc4d
Limit editable hotspot movement to arbitrary values
Hello,
 I would like to have a editable hotspot to move only by given values but obviously I get a numeric error when I check the script.
Is there a way to "limit" the hotspot's movement to the given values only?
Practical example 🙂
On the parameters tab I have this:
VALUES "Height", '1420', '1580', '1880', '2120', '2280', '2990'
On Master:
unID = 1
On the 3D script
HOTSPOT 0,0,0, unID, Height, 1+128
unID = unID+1
HOTSPOT Height,0,0, unID, Height, 2
unID = unID+1
HOTSPOT -1,0,0, unID, Height, 3+128
unID = unID+1
Juan.
2 Solutions
The hotspot movement is a length, so your 'Height' parameter needs to be a 'length' type and not 'text' type.
The value list will be lengths in meters with not quotes ...
VALUES "Height", 1.420, 1.580, 1.880, 2.120, 2.280, 2.990
Go to post
Lingwisyer
Guru
You could use Range and Step to do something along the lines of
VALUES "Height" range [1, 3] Step 1, 0.2
Ling.
Go to post
7 Replies 7
jc4d
Ohh, that easy, thank you. I need to take a break 😅
jc4d
I hope is ok to ask another question here since it is somewhat related. If not the mods are free to move it to a new topic.
Is it possible to give a max and min lenght limits to the hotspot and define the movement steps?
Juan.
Lingwisyer
Guru
Ling.
jc4d
Thank you, sadly I get an error:
Juan.
Lingwisyer
Guru
Probably bad syntax on my part. I have not used the values command with range and step before. Updated previous post with what I think is the correction. Had an extra comma.
jc4d
Fantastic, thank you 🙂
