Bruce
MVO array dimensions won't update
I've changed parameter arrays in a previously deployed MVO from 2-dimensions to 1-dimension arrays.  I have updated all my relevant scripts and macros etc,  The really odd thing is that in the GDL scripting environment, I don't get any errors - but when I open the MVO dialog, I do get errors.
I've managed to track down the problem, and it's that the MVO in the Archicad environment is still treating these parameters as 2-dimension arrays.  For some reason, it 'remembers' that these parameters used to be 2-dimension arrays.
So far I've:
  1. deleted all MVOs bar one (can't delete the last one).
  2. created new MVOs
  3. closed and re-opened the file
  4. unloaded the relevant parts, opened the MVO, reloaded
  5. unloaded the relevant parts, closed the file & reopened, reloaded
None of the above worked, but while I was typing out this post, I thought of something that did work: save as the MVO gdl part as a New Library Part.  Delete the old one, use the new one.  That seemed to do the trick.
Even though I solved the problem, I figured I'd post anyway, just in case someone has the same problem in the future.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
1 Solution
Bruce
Yes, that's there as well.  Works in the scripting environment, but crashes in the Archicad environment due to incorrect array dimensions.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Go to post
Curious if you have a parameter loop in the parameter script to shrink your arrays?
Might work for future endeavors
Bruce
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
