New API developer
Hello; I am a french beginning developer.
I have developed little Java application, and most of my work outside ArchiCAD was on Web Applications using Php.
These two years I have worked on complex GDL object development.
But now I have a project on the table for an API for Archicad using a part In GDL and an other part coding API. I think I could handle C or C++ but I really don't know how to start to develop an API.
Could I found some examples that I could Launch on Archicad And Compile it on a Mac without using Software like VS 2003?
Thank you for your answer
PS : I have already begin to fill the graphisoft Application Form to have My own API developer ID; But I have not done anything else
21 Replies 21
ares997
I hope the next version of archicad doesn't not support PPC, that would mean that half of my office would be out of luck and my personal system at home (a G5 quad $5000 2.5 years ago is also not worth it's weight in gold even though it still can keep up with an intel machine.)
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
Well, at the risk of switching a Developer forum topic into a general discussion...
You'll note also that Apple is no longer supporting PPC with OS X Snow Leopard (10.6) which is arriving in a few months. It will be interesting to see when Apple drops PPC support from their applications software.
It is a challenge that drains resources from GS to maintain the PPC as well as Intel platforms, so I am sympathetic to their decision.
Note that your PPC will be able to continue to run Leopard and AC 12 and all of your other current apps indefinitely of course... so to the extent that the economy is killing all of us, I suspect some people will just hang on to their PPC machines and old versions for a while and postpone upgrades.
Old PPC macs can make decent servers, so even if you don't keep them, you will find a resale market.
Sympathy,
