Domagoj Lukinic
PROJECT2{2} background color
Hi all,
I do not understand PROJECT2{2}  command...
My main goal is to get a fill from projected 3D surface, however when I assign a background color it does not work...
What am I doing wrong?
PROJECT2{2} 2,90,32+512,3,0,0,45
1 Solution
Domagoj Lukinic
I forgot to replay on my own post...
I already solved the problem, my "method" was wrong. I was constantly setting 2 witch is hidden lines (analytic) but I needed to use 3=shading.
Go to post
Jarrod Phillips
Hi @Domagoj Lukinic,
Not entirely sure if I am understanding your question, however, if you are looking to add a coloured background fill to your 3D projection, you can do this by setting up a background pen parameter and a fill type parameter and referencing them in the 2D script (see example below).
Parameters:
gs_fill_type
gs_back_pen
2D script:
set fill gs_fill_type
project2{2} 3, 270, 3 + 32, gs_back_pen
Hope this helps!
Jarrod.
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 27
Domagoj Lukinic
