jc4d
Prism_ hole not drawing final arc
Hello,
I have a prism_ (rectangle) and another one that contains arcs on each corner (rounded rectangle).
If I draw each one separately in 3D is fine, the problem is when I want to use the rounded rectangle as a hole of the main rectangle.
-Simple rectangle:
-Rounded rectangle:
The problem as you can see, there is one corner that is not drawing the arc
I have based the code from the GDL reference guide (not the actual code of my objects)
ROTX 90
PRISM_ 26, 1.2,
    0.3,   0,    15,
    0.3,   0.06, 15,
    0.27,  0.06, 15,
    0.27,  0.21, 15,
    0.25,  0.23, 15,
    -0.25, 0.23, 15,
    -0.27, 0.21, 15,
    -0.27, 0.06, 15,
    -0.3,  0.06, 15,
    -0.3,  0,    15,
    0.3,   0,    -1,    !End of contour
    0.10,  0.03, 15,
    0.24,  0.03, 15,
    0.24,  0.2,  15,
    0.10,  0.2,  15,
    0.10,  0.03, -1    !End of first hole
Juan
1 Solution
jc4d
Forgot to close the shape. Now everything works 🙂
Go to post
jc4d
