2018-06-05
11:15 AM
2022-09-26
10:57 PM
Daniel Kassai
Solved! Go to Solution.
2018-06-20 05:00 AM
!!!! group lowergroup
!!!! for nSide = 1 to nTransformedPoly
!!!! if segmentCutFlag[nSide] then
!!!! _cutangle = segmentCutAngle[nSide]
!!!! else
!!!! _cutangle = 0
!!!! if segmentContinueFlag[nSide] then
!!!! if segmentSideFlag[nSide] = SIDE_END then _cutangle = _cutright
!!!! if segmentSideFlag[nSide] = SIDE_START then _cutangle = _cutleft
!!!! endif
!!!! endif
!!!! put transformedPoly[nSide][1], transformedPoly[nSide][2],
!!!! _cutangle, transformedPoly[nSide][TRPOLY_STATUS], _matPanel
!!!! next nSide
!!!! cprism_{2} _matPanel, _matPanel, _matPanel,
!!!! nTransformedPoly, ac_panelThickness / 2,
!!!! get(nsp - 2), -1, _matPanel
!!!! gosub "flushBuffer"
!!!! endgroup
!!!! group uppergroup
!!!! else
!!!! _cutangle = 0
!!!! endif
!!!! endif
!!!! put transformedPoly[nSide][1], transformedPoly[nSide][2], ! [nSide][3] should be all the same
!!!! -_cutangle, transformedPoly[nSide][TRPOLY_STATUS], _matPanel
!!!! next nSide
!!!! addz ac_panelThickness
!!!! mulz -1
!!!! del 2
!!!! endgroup
Directly after that add this ...!!!The geometry for all the corner points
horiz_panel = (transformedPoly[2][1]-transformedPoly[1][1])*COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
vert_panel = (transformedPoly[3][2]-transformedPoly[2][2])/COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
end_rise = (transformedPoly[2][1]-transformedPoly[1][1])*SIN(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
cross_angle = ATN((vert_panel+end_rise)/horiz_panel)
panel_cross_angle_1 = cross_angle-panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]
cross_x_rad_1 = (rail_hgt*0.5)/SIN(panel_cross_angle_1)
cross_y_rad_1 = (rail_hgt*0.5)/SIN(90-panel_cross_angle_1-panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
y_reduction_1 = cross_y_rad_1-(cross_y_rad_1*COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]))
if panelSegmentData[iSegment][SEGMENT_SLOPEANGLE] <> 0 then
x_reduction_1 = y_reduction_1/TAN(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]*0.5)
else
x_reduction_1 = 0
endif
panel_cross_angle_2 = ATN((vert_panel-end_rise)/horiz_panel)+panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]
cross_x_rad_2 = (rail_hgt*0.5)/SIN(panel_cross_angle_2)
cross_y_rad_2 = (rail_hgt*0.5)/COS(panel_cross_angle_2-panelSegmentData[iSegment][SEGMENT_SLOPEANGLE])
y_reduction_2 = cross_y_rad_2-(cross_y_rad_2*COS(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]))
x_reduction_2 = y_reduction_2/TAN(panelSegmentData[iSegment][SEGMENT_SLOPEANGLE]*0.5)
else
x_reduction_2 = 0
endif
group lowergroup
put transformedPoly[1][1], transformedPoly[1][2],
0, 15, _matPanel
put transformedPoly[1][1]+cross_x_rad_1, transformedPoly[1][2],
0, 15, _matPanel
put transformedPoly[3][1]-x_reduction_1, transformedPoly[3][2]-cross_y_rad_1+y_reduction_1,
0, 15, _matPanel
put transformedPoly[3][1], transformedPoly[3][2],
0, 15, _matPanel
put transformedPoly[3][1]-cross_x_rad_1, transformedPoly[3][2],
0, 15, _matPanel
put transformedPoly[1][1]+x_reduction_1, transformedPoly[1][2]+cross_y_rad_1-y_reduction_1,
0, 15, _matPanel
0, 15, _matPanel
7, ac_panelThickness / 2,
gosub "flushBuffer"
put transformedPoly[2][1], transformedPoly[2][2],
0, 15, _matPanel
put transformedPoly[2][1]+x_reduction_2, transformedPoly[2][2]+cross_y_rad_2-y_reduction_2,
0, 15, _matPanel
put transformedPoly[4][1]+cross_x_rad_2, transformedPoly[4][2],
0, 15, _matPanel
put transformedPoly[4][1], transformedPoly[4][2],
0, 15, _matPanel
put transformedPoly[4][1]-x_reduction_2, transformedPoly[4][2]-cross_y_rad_2+y_reduction_2,
0, 15, _matPanel
put transformedPoly[2][1]-cross_x_rad_2, transformedPoly[2][2],
0, 15, _matPanel
0, 15, _matPanel
gosub "flushBuffer"
endgroup
group uppergroup
mulz -1
_cutangle, 15, _matPanel
gosub "flushBuffer"
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
gosub "flushBuffer"
del 2
endgroup
!!!! _yCurr = _pageStartY + 37
!!!! ui_infield{3} ac_panelThickness, _x2, _yCurr, _infWidth, _infHeight
Then add ...
ui_infield{3} ac_panelThickness, _x2, _yCurr, _infWidth, _infHeight UI_TOOLTIP "Rail Width"
ui_infield{3} rail_hgt, 380, 130, 50, _infHeight UI_TOOLTIP "Rail Height"
2018-06-12 10:45 AM
2018-06-17 10:55 AM
2018-06-18 05:04 AM
2018-06-18 09:25 AM
2018-06-20 04:42 AM
2018-06-20 05:00 AM
!!!! else
!!!! _cutangle = 0
!!!! endif
!!!! endif
!!!! next nSide
!!!! endgroup
!!!! else
!!!! _cutangle = 0
!!!! endif
!!!! endif
!!!! next nSide
!!!! mulz -1
!!!! del 2
!!!! endgroup
else
x_reduction_1 = 0
endif
else
x_reduction_2 = 0
endif
group lowergroup
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
gosub "flushBuffer"
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
gosub "flushBuffer"
endgroup
group uppergroup
mulz -1
gosub "flushBuffer"
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
0, 15, _matPanel
gosub "flushBuffer"
del 2
endgroup
Then add ...
2018-06-22 06:07 AM
2018-06-26 10:26 AM
In the parameter script find these line starting at line 62 and comment them out.
2018-06-26 03:05 PM
